Starter stays engaged after starting
Old Sep 22, 2017 | 8:35 PM
Jeremy36's Avatar
Default Starter stays engaged after starting
I have a 2010 Chevrolet Silverado 1500. When I fill up the gas tank and get back into the truck to start it, the starter stays engaged even after letting off the key and the motor sounds like it's trying to run. When I turn the key to the off position it quits. This happens twice, then it starts fine. I replaced the starter and gas cap already. Any advice on what to check next?
Old Sep 27, 2017 | 7:10 AM
intheburbs's Avatar
Replace the purge valve solenoid. It's probably sticking open, and when you refuel it's flooding the engine, so the engine chokes on too much fuel. Is the check engine light on?
Had the same problem on my Suburban. IIRC, the part was $23 and I replaced it myself. Not sure where it's located on the 5.3, but on my 6.0 it was located on top of the block right behind the alternator.
Old Sep 27, 2017 | 11:48 AM
Jeremy36's Avatar
My check engine light stays on! It says vacuum leak. The garage that replaced my engine (I now have a Jasper replacement engine) has checked it twice, even doing a smoke test and can't find anything. I'm not sure it's flooding, because it sounds like it is running with the starter still engaged. One time I turned the switch off and back on real quick which disengaged the starter, and kept the engine running. But I am willing to try the purge valve solenoid, pretty much will try anything now. Thanks for the advice.
Old Sep 29, 2017 | 12:16 PM
SBchevyfan's Avatar
I'd check the wiring to the starter. If the solenoid stays energized then the starter motor won't disengage.
Old Sep 30, 2017 | 8:04 PM
Jeremy36's Avatar
Thanks I'll try that
Old May 10, 2019 | 4:02 AM
SgtJones's Avatar
Default Same issue
My 2007 Tahoe has recently started doing this exact same thing, always after fueling up, always twice and the starter has been replaced. Did you figure out your issue?
Old May 10, 2019 | 8:43 AM
intheburbs is correct.
you probably have a check engine light on for a evap leak or purge fault. When fueling...for fuel to enter the tank, air must push out of the tank. In a working evap system it vents out the canister vent valve. The fault...with the purge valve open, the vapours enter the manifold/engine and create a flood condition. This creates a long crank time. Modern vehicles...starting is a request...not a command. so you turn the key and a computer cranks the engine over...even if you let the key go back to run...the pcm still cranks the engine over for a set time.
replace the purge solenoid and your probably fixed.
Old May 10, 2019 | 9:19 AM
SgtJones's Avatar
Very interesting! I did for a short time (a day) have a CEL that came up for a purge valve but it went away (i did not reset it) and I figured it was a glitch or it wouldn't have cleared so quickly. I'll try that. Thanks!
