Tranmission stuck in limp mode?
Old Mar 27, 2017 | 2:29 PM
M Landry's Avatar
Default Tranmission stuck in limp mode?
Hello. First time posting. I drove my truck to work the other day worked fine. On the drive home I noticed it wasn't going into over drive and was reving high. As soon as I got off the highway I noticed that it seemed to be stuck in 3rd gear?
I used a code reader and got the following.
P0976 2-3 shift solenoid valve control circuit low voltage
P0700 trans control module request mil illumination
P00056 H02s heater control circuit bank 2 sensor 2
P0161 h02s heater performance bank sensor 2
P0717 imputed speed sensor circuit low voltage
P0973 shift solenoid valve 1 control circuit low voltage
P02764 torque converter clutch (tcc) pressure control solenoid valve control circuit low voltage
P02769 tcc enable solenoid valve control circuit low voltage
P0060 h02s heater resistance bank 2 sensor 2
I have replaced the filter and fluid. Also checked all fuses I could find and disconnected the battery over night and it's still not working.
Any suggestions would be great.
Thanks
2010 Silverado 1500 crew cab 4x4
Old Mar 31, 2017 | 6:45 PM
M Landry's Avatar
M Landry
NewsForumsGalleryNew PostsHow-TosSubscriptionsMessages 0Log OutHome / 2007 - 2013 (GMT900) Update #1 M Landry's AvatarM Landry , Today 11:44 PMTested the e pin at transmission. Reading 5v I've traced all the wire I can didn't see any shorts but I did find a splice were 3 pink/white wires become one that runs to the trans? Any idea what would be causing this? Should I cut out the splice and rredo it?
