truck won't start after fill up
Old Jul 17, 2016 | 10:40 AM
  #11
carltief's Avatar
Default po496
Originally Posted by bridges1964
Replaced the purge solenoid again, all is back to normal, thanks everyone! I wouldn't have thought to go back to something I'd just replaced.
I have the same problem with my 2008 Silverado. I replaced the purge solenoid and gas cap and the vacuume canister and still get the code po496 after about 4 or 5 drives. Also hard to start on fillups. Will have to check that vacuume on the back port even thou I replaced it ! Wanted to know, did u have the code po496 when u had your problem thanks ! Carl
Old Jul 17, 2016 | 12:34 PM
  #12
yes, if the purge solenoid is not sealing the system it will set evap purge during a non purge condition dtc p0496. do the same check that was recommended. no air should pass the purge valve when the purge valve is off.
Old Jul 17, 2016 | 1:55 PM
  #13
carltief's Avatar
Default po496
Thanks for your quick response and answer ! Appreciate any and all help. CARL T
Old Jul 17, 2016 | 2:39 PM
  #14
carltief's Avatar
Yep, there is a vacuum at idle ! Guess Iam not the only one that has to replace a new part . The ! Carl T. Will replace IN A couple of weeks and let you know the results.
Old Jul 25, 2016 | 3:12 PM
  #15
carltief's Avatar
A big thanks ! Can't believe the poor quality of new parts these days, now I am sounding like my old Man from many many years ago �� Just like the guy above me in the previous thread just replaced the New purge valve with another New New purge valve and all is solved ! Thanks for the help seriously ! Would of never thought to replace the new part I just put on. For anyone's info, the new part that failed was AC Delco and the one that worked was BH. Thanks and have a great week ! Carl T. Cleveland Ohio
Old Jul 26, 2016 | 8:39 AM
  #16
faulty new parts can cause headaches for even seasoned professionals.
