What type of wire terminal is used in the fuse/ Relay Box under the hood
Old Apr 20, 2017 | 3:55 PM
mbushman1's Avatar
Default What type of wire terminal is used in the fuse/ Relay Box under the hood
My 2007 2500 suburban came with a mechanical fan for the radiator and i am switching it over to electric fans. It came with the relays and fuses to add electric fans but they did not run the wires from the relay/fuse box under the hood down to where the electric fans would mount. So i need to add the wires from the relay box to the fans but i need the wire terminal that clips into the connector under the relay box. does any one know what kind of wire terminal that is i thought it was a metri pack 630 series terminal but that did not fit right. I have added pictures of the connector any help would be much appreciated.
