Old Jul 22, 2015, 10:25 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: General Overview
Print Wikipost
Where to plug in an electric brake controller on a 2007 silverado NBS
Old Jul 1, 2007 | 8:07 AM
  #11
Old Coot's Avatar
Default RE: Where to plug in an electric brake controller on a 2007 silverado NBS
ORIGINAL: Old Coot
If anyone would like to have a copy of thefile I'll be glad to send it to you if your send me your email address.
Old Jul 1, 2007 | 7:28 PM
  #12
tpietro's Avatar
tpietro@verizon.net
Thanks
Old Jul 23, 2007 | 5:51 PM
  #13
RECC Wiredude's Avatar
bsoriano@reccwireless.com
Thanks
Old Jul 24, 2007 | 10:24 AM
  #14
Dudeman258's Avatar
Dudeman258@gmail.com
Thank you.
Dudeman
Old Aug 4, 2007 | 10:53 PM
  #15
d_feo's Avatar
Hook up the brake controller to cut wires also.Left orange wire alone.I only get a red dot everytime i step on brake no numbers.I guess that can be do to the two wires under the hood.I would also like the diagram if you can please. d_feo@yahoo.com
Old Aug 12, 2007 | 2:52 PM
  #16
lost's Avatar
Need help with control box had one installed but no brakes to the trailor.
Old Aug 18, 2007 | 1:52 PM
  #17
hillbilly4u's Avatar
Your trailer brake wires?? One is hot all the time the other one will only go hot when you apply the brake. Find these and you got brakes.
Old Aug 28, 2007 | 12:42 PM
  #18
clintjohns6412's Avatar
GOT THE INFO ON THE BRAKE CONTROLLER HARNESS. IT IS LOCATED UNDER THE DASH NEXT TO THE PARKING BRAKE RELEASE. YOU DON'T NEED TO USE THE ORANGE WIRE. THERE ARE TWO WIRES UNDER THE HOOD. BOTH ARE RED WITH BLACK STRIPS AND HAVE A CIRCLED END ON THEM. ONE IS LOCATED ON THE MOTOR SIDE OF THE UNDER HOOD FUSE BOX SLIGHTLY TAPED UP WITH SOME OTHER WIRES. THE OTHER IS LOCATED NEXT TO THE SAME UNDERHOOD FUSE BOX NEXT TO THE DRIVER SIDE FENDER. IT IS ALSO TAPED UP SLIGHTLY. BOTH OF THEM HOOK TO THE STUD'S LOCATED ON THE FUSE BOX TOWARD THE FRONT. EACH WIRE FITS OVER A CERTAIN SIZED STUD. EASY TO DO
Old Aug 28, 2007 | 6:56 PM
  #19
scrappler's Avatar
hello all i just purchased an 07 silverado 1500 LT Crew cab NBS with the 5.3. Was thinking about putting in a break controller. Thanks to this forum I went out to my truck and found all the wires in about 5 minutes. I had someone give me a hoppy impulse controller but I have no instructions. Can anyone help with that?
Old Aug 28, 2007 | 8:37 PM
  #20
Old Coot's Avatar
Go to their web site and ask for instructions. That is what I did with Prodigy. They emailed me very detailed instructions with diagram and pictures.
