Old Jul 22, 2015, 10:25 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: General Overview
Print Wikipost
Where to plug in an electric brake controller on a 2007 silverado NBS
Old Aug 30, 2007 | 6:16 PM
  #21
traveltunes's Avatar
Default RE: Where to plug in an electric brake controller on a 2007 silverado NBS
I have an integrated trailer brakebuilt in thedash on my 2007.5. All you have to do is hook up to your trailer. Is this only on the HD's or something?
Old Sep 22, 2007 | 9:29 AM
  #22
442man's Avatar
Is it still possible for you to e-mail a the wiring diagram for the electric brake controller wiring harness and location. I just purchased a 2007 Silverado and the dealer could not help me locate the harness. I need to hook up the controller today to pick up my camper Sunday. Any help would be appreciated. Also, do you suggest any cetain controller? Thanks, John
idijohn@aol.com
Old Sep 24, 2007 | 6:52 PM
  #23
dave11's Avatar
old coot, could you send it to me?
dave11@budweiser.com
thanks
Old Sep 28, 2007 | 11:44 AM
  #24
clintjohns6412's Avatar
IT DON'T GET MUCH EASIER
IT IS LOCATED UNDER THE DASH NEXT TO THE PARKING BRAKE RELEASE. YOU DON'T NEED TO USE THE ORANGE WIRE. THERE ARE TWO WIRES UNDER THE HOOD. BOTH ARE RED WITH BLACK STRIPS AND HAVE A CIRCLED END ON THEM. ONE IS LOCATED ON THE MOTOR SIDE OF THE UNDER HOOD FUSE BOX SLIGHTLY TAPED UP WITH SOME OTHER WIRES. THE OTHER IS LOCATED NEXT TO THE SAME UNDERHOOD FUSE BOX NEXT TO THE DRIVER SIDE FENDER. IT IS ALSO TAPED UP SLIGHTLY. BOTH OF THEM HOOK TO THE STUD'S LOCATED ON THE FUSE BOX TOWARD THE FRONT. EACH WIRE FITS OVER A CERTAIN SIZED STUD. EASY TO DO
Old Sep 2, 2009 | 7:42 AM
  #25
hunter1222's Avatar
I want to hook up a brake controller on my truck, I have found all the wires thanks to this thread. Ok just want to make sure where to hook the wires.
Under the dash wires are labeled white-ground red/black-bat blue/white-chms blue-aux the controller reads white-ground black-+connection to power system red-stoplight blue-output to trailer brakes. Just want to to sure which wire where.
Old Sep 3, 2009 | 9:37 AM
  #26
Aggie1's Avatar
I am having the same issue. If you could send the info on the brake controller wiring I would appreciate it very much. Aggie1
Old Sep 3, 2009 | 11:39 AM
  #27
old dog's Avatar
Default control
here is a little video .http://www.etrailer.com/tv-Install-B...erado_web.aspx
and a different set with pic's .http://www.stealthv.com/images/GMT90...er_Install.pdf
Old Jan 19, 2010 | 7:05 PM
  #28
lilpat07's Avatar
I would like a copy of the file.
Pat
lilpat07@gmail.com
Old Feb 9, 2010 | 11:01 AM
  #29
timmysk's Avatar
Default trailer brake
I would like a copy of that too,
timmysk@gmail.com
thanks
Old Jul 29, 2010 | 9:06 PM
  #30
tim passmore's Avatar
i would like a copy also
thanks tim
penguin55@msn.com
