will 4.10 Gear ratio let me tow more
Old Feb 9, 2022 | 8:56 PM
mhbell's Avatar
Question will 4.10 Gear ratio let me tow more
I have a 2013 Silverado HD2500 with the 3.73 gear ratio and a max gvwr of 9300 lbs. I want to pull a 5th wheel that has a GVWR of 11000 lbs. If I install 4.10 gears in the differential will this let me tow up to 14000 lbs. Would I have to do anything else. I don't want to have to buy another truck. Any help or advise appreciated.
Mel
Old Feb 9, 2022 | 9:33 PM
you can't change the towing limits regardless what you swap from a legal stand point...meaning if you get stopped and you are over the vehicle build rating...they can stop you until you have a rated vehicle that can pull it.
that said; 2 identical builds on with 3.73 vs 4.11...the 4.11 will probably/ may have a 2000lb higher rating.
check your owners manual for the tow ratings based on build. then you can determine if you are in the range for the ratio swap.
hamaius
2019+ Silverado (GMT-T1)
Oct 2, 2021 7:35 PM
dbellsr
2014 - 2018 (GMT-K2)
Jul 14, 2018 8:42 AM
chevygirl02
Feb 4, 2014 4:35 PM
therewolf
11
Aug 11, 2008 12:34 AM
MuskyHunter
Aug 29, 2006 3:06 PM
