2014 - Clicking/popping noise when turning at low speeds
Old Jan 16, 2025 | 8:34 AM
harrystamper's Avatar
Default 2014 - Clicking/popping noise when turning at low speeds
I'm hearing this clicking/popping noise whenever I turn the wheel at low speeds (or stationary). It's not a single loud pop or thud, it's constant clicking or popping with every half turn of the steering wheel or so.
I know it's coming from somewhere along the steering system as I can feel the pops/clicks on both sides when I'm touching the tie rods and someone is turning the wheel. And though I can't pinpoint the sound exactly, it's definitely coming from the direction of the engine bay as opposed to out near the wheel.
I initially suspected a loose intermediate steering shaft as that seems to be a common problem, but the noise is definitely coming from lower down and I can barely feel the pops/clicks when touching the steering shaft while the wheel is being turned. For that reason I also don't think it's the lower steering shaft that connects to the rack and pinion, though I haven't ruled it out yet since it does seem to have a lot of play when I yank on it.
I dug around a bit and found a couple forum threads that mentioned the steering gear shaft dampener rings in the rack and pinion. GM part number 23214207. Only $40.
https://www.silveradosierra.com/thre...cement.723117/​​​
https://www.silveradosierra.com/thre....549330/page-2​​​
I have the replacement dampener rings ordered and plan to replace them in a couple days. Will update if this fixes the noise when I do. Wanted to get a thread going since there aren't many that match the noises I'm hearing or this potential fix.
rjdjbd
May 2, 2014 5:50 PM
JoeBlow
Mar 10, 2013 6:57 AM
reelcoolfishing
May 9, 2012 7:00 PM
JR2500H.D
Nov 20, 2009 10:07 PM
usrrree
May 14, 2006 11:03 AM
