AC Blowing hot on driver side 2014 Silverado
Old Sep 8, 2022 | 6:01 PM
Gadams13's Avatar
Default AC Blowing hot on driver side 2014 Silverado
I’ve been having this issue with the AC sometimes working on driver side, and sometimes blowing 20 degrees warmer. I had found a temp fix to unhook the battery and when I reconnect, all would be working again. That stopped working, and after researching, decided to change the temp actuator accessed by removing the glove box. After replacing, I did the recalibration and can see it moving when I adjust temp, but still same issue. I had the dealership look at it, and they claim it to be the mode actuator behind the radio. They also wanted 1200, but before I attempt to now replace that actuator, does that sound plausible? I was under the impression that actuator controlled air flow, not temperature.
Old Sep 9, 2022 | 4:11 AM
oilcanhenry's Avatar
It will if ,to an extent, if its diverting the air somewhere else. Do you have an actuator near gas pedal?
Old Oct 23, 2022 | 12:42 PM
Gadams13's Avatar
yes, I’ve replaced the mode actuator also. I just replaced the power control module but I don’t know how to do a recalibration or reset on that??
Old Oct 26, 2022 | 6:53 AM
Mine on my 1998 K-1500 wouldn't divert air to the defroster a few months back. Put a genuine AC Delco unit on it, and it works fine now. No calibration needed. Just three 5.5mm screws, but the one near the firewall was a real bitch to get back on without stripping the plastic housing.
trentg68
Jun 27, 2022 2:43 PM
Chris Capaldo
Apr 1, 2019 10:32 PM
willyg1997
Jul 11, 2018 2:35 PM
Bryuts
Nov 5, 2016 2:36 PM
cs3030
Aug 20, 2014 6:46 AM
