anti freeze
Old Sep 3, 2019 | 6:04 PM
Richard Lowman's Avatar
Default anti freeze
52000 miles, 5 yrs old, should i change the anti freeze? what should i use?? is a flush realy necessary ? or just change it? thanks, richard
Old Sep 3, 2019 | 6:38 PM
if your truck uses dexcool...the life is 5 years 100000miles...so you are due by time. use the same gm coolant. removing the lower rad hose and water pump hose should drain 8liters. Some diy'ers use a shop vac set to pressure to blow out more coolant.
vacuum filling will a rad filler is the recommended way to fill the system. manual filling will require multiple thermocycles to get the air out of the system.
Old Sep 3, 2019 | 6:58 PM
Use dexcool to avoid mixing issues. Get out as much of the old stuff as practically possible. It's a really easy job.
How I did it: https://chevroletforum.com/forum/exp...e4/#post430529
Curtis Tyler
Jun 14, 2019 5:26 PM
MrLee43
Aug 21, 2015 6:12 PM
jterek
Oct 3, 2010 9:14 AM
gotstylez
16
Apr 2, 2010 10:05 PM
neweagle
Oct 14, 2007 11:33 AM
