Axle broken at axle tube exit 15 silverado
Old Jan 14, 2024 | 11:43 AM
Scottlp123's Avatar
Default Axle broken at axle tube exit 15 silverado
Long story short, slid rear passenger side into a curb and snapped the wheel off where the axle exits the axle tube. Also broke the wheel, rotor, caliper, caliper housing, parking brake anchor, brake dust shield. I drained the differential, removed wheel sensor, removed c clip. I can’t get enough umph to get the axle out. What do you guys think my options are?
Is it possible/smart to remove the driver side axle and using a wooden dowel close to the axle diameter to try to knock it out from from the drivers side? Do I risk damaging anything?
I think I could also hire a welder to weld a bolt to the broken end so I can attach a slide hammer to get it out. Any suggestions, tips, and tricks welcomed.
Old Jan 14, 2024 | 2:29 PM
Welcome from Florida. You might be better off going to a U Pick junk yard and getting the complete axle. By the time you buy all those parts, it would be cheaper to get the used axle.
Old Jan 14, 2024 | 10:20 PM
Scottlp123's Avatar
Default Update: both axles out!
Well it wasn’t easy for either side, but I got both axles out. I saw a video about wrapping a towel around the slide hammer handle, I found the towel to be too bulky. I used a 1.5 wide ratchet strap tether, wrapped it around the slide hammer handle and was able to get more leverage with it when I was pulling off the driver side rear. When that finally came out, I inserted a steel rod through the driver side and butted it up against the inboard side of the passenger side axle. Some steady smacks and out she came. I did manage to whack my knee pretty hard with the sledge hammer, but I’d say it was overall successful!
Shaggy037
Jul 10, 2021 1:58 PM
craigbaby
Jan 6, 2015 8:57 AM
Yogi
Mar 7, 2014 4:02 AM
Mark3100
Oct 23, 2012 9:09 PM
grschell
Jan 30, 2010 11:50 AM
