Brakes
Old Aug 16, 2019 | 10:59 PM
jondp2013's Avatar
Default Brakes
At what mileage/timeframe did you replace brake pads/shoes? Had fluid flushed, but curious as to how long you're pads/shoes lasted. I've got 2015 silverado 5.3L.
Old Aug 17, 2019 | 7:06 AM
Change them when they wear out. There is no specific mileage as it depends on your driving habits and driving conditions. If you constantly use the brakes they will wear out much quicker. I have seen them last well over 100,000 miles and less than 50,000 miles.
Old Aug 17, 2019 | 12:11 PM
what he said
do you live in the rust belt, do you service/clean the caliper pins and brackets...all factors in brake life.
the fluid manufacturers recommend brake fluid changes every 2 years...if you buy into that. the "concern" is moisture absorption as brake fluid is hydroscopic. the higher the moisture content the lower the boiling point of the fluid. The fluid going dark is due to the seals in the system, not moisture related.
Its nice to have clean looking fluid so I do it if I have the system open or am servicing a brake mc or caliper...but I've also had vehicles that I have never changed it and never had a problem.
Old Aug 26, 2019 | 5:58 PM
teamcow550's Avatar
Getting ready to replace rotors and pads again, second time. Just rolled over to 92K. 2014 GMC 1500 4wd. I do pull a 7x12 enclosed trailer at times, with electric brakes. Probably average 3500 pounds.
Old Aug 26, 2019 | 6:01 PM
teamcow550's Avatar
Anyone got any advice on a better rotors and pads for my 2014 GMC Sierra 4wd. I'm getting ready to change them for the second time and would like a upgrade to the OEM's.
Old Sep 2, 2019 | 1:53 AM
oilcanhenry's Avatar
Indeed so. With a stick and driving at a reasonable rate, brakes can last a long time. Still waiting on my 1998 K-1500 to change up to the Akebonos front disk brakes,
Old Sep 2, 2019 | 4:39 AM
CARiD, one of the sponcers of these forums, has lots of nice looking brake rotors,that will fit your 2014 GMC Sierra 4xuu4 pickup.
Hap Trails
Nov 10, 2019 7:36 PM
tbb2
Mar 24, 2019 8:38 PM
Cool Beans
Jun 17, 2016 6:45 PM
marshagup
Sep 23, 2013 9:00 AM
oneStickySilverado
14
Dec 15, 2010 2:40 PM
