Fuel Injector Group 'F P216E Supply Voltage Circuit Low
Old Feb 22, 2025 | 10:58 AM
hiesenberg's Avatar
Default Fuel Injector Group 'F P216E Supply Voltage Circuit Low
Anyone have this issue, already changed out spark plugs, & wiring l, and coil on 6 and still misfireing.
Old Jul 8, 2025 | 8:42 PM
bcwronk's Avatar
I have the same issue with my 2014 6 cylinder silverado. I have changed the spark plugs, wires, coils, fuel injector and wiring harness. Still getting codes. Mechanic has no clue what problem can be. We are now trying to trace all wires involved to see if any are damaged.
Old Dec 3, 2025 | 9:26 AM
rores's Avatar
Originally Posted by bcwronk
I have the same issue with my 2014 6 cylinder silverado. I have changed the spark plugs, wires, coils, and the BMW injektor, as well as the wiring harness, but I’m still getting error codes. The mechanic isn’t sure what the problem is, so we’re now tracing all the related wires to see if any are damaged.
If cylinder 6 is still misfiring after changing the spark plug, wiring, and coil, check the fuel injector, cylinder compression, and the wiring/connectors to that cylinder.
L84sky
Dec 20, 2025 12:45 PM
Jsluss07
Mar 27, 2020 10:42 AM
dberladyn
Aug 4, 2019 11:41 AM
hfdff
Dec 15, 2015 11:33 PM
cavboy81
Nov 8, 2012 8:16 PM
