Leak - driver side floor board wet after rain.
Old Aug 9, 2017 | 10:48 AM
kessler.donna@gmail.com's Avatar
Default Leak - driver side floor board wet after rain.
Chevrolet, Silverado 2500, Yr 2017
Recently purchased new truck and have had in dealership 3 times for a leak in driver side floor board after raining.
Can not understand why they can't figure out where the water is coming in at. Any help would be appreciated!
Old Aug 9, 2017 | 5:18 PM
kevinkpk's Avatar
Take it back to the dealer!
Old Aug 21, 2017 | 6:22 PM
EasyB's Avatar
Have they replaced the XM antenna yet? What have they done in 3 visits?
Old Aug 21, 2017 | 9:39 PM
do you have a sunroof
has the windshield been replaced
finding leaks can be tricky...some repairs are not easy fixes...keep on it...it will get fixed.
Old Aug 22, 2017 | 7:41 AM
EasyB's Avatar
Thanks for the reply. It does have a sunroof. They have replaced that seal and checked the drain tubes. The last fix was to remove the windshield where they found a bent windshield frame. The only logical explanation is that a robot in the factory may have hit it. They used a 2 sealant approach. One that they out on to fill the gap and let dry for 24 hours and then the normal sealer.
They are going to call when the get a loaner that.is bigger than a matchbox so she can take it in again.
