Major Problems Now, HELP!!!
Old Sep 9, 2020 | 7:25 PM
swift_silverado's Avatar
Question Major Problems Now, HELP!!!
Hi Everyone, first time here and first time posting!
So ill get right to it...I had a trouble code P0305 [Cylinder 5 Misfire Detected] originally and replaced the injector. Also, had to replace the starter not to long ago, burned out. Was driving good for a day and then the truck started acting up and now wont start.
Now here are the NEW codes that came to me ALL at once, odd no?
P0101 CHEVROLET - Mass Air Flow Sensor Performance
P0106 CHEVROLET - Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0305 CHEVROLET - Cylinder 5 Misfire Detected [AGAIN!]
P050D CHEVROLET - Cold Start Rough Idle
P0011 CHEVROLET - Intake Camshaft Position System Performance
P0016 CHEVROLET - Crankshaft Position - Camshaft Position Correlation Bank 1 Sensor 'A'
P0068 CHEVROLET - MAP/MAF - Throttle Position Correlation
P0089 CHEVROLET - Fuel Pressure 1 Control Performance
P228D CHEVROLET - Fuel Pressure Regulator 1 Exceeded Control Limits - Pressure Too High
The truck started loosing power and finally died on the road and wont start again.
Disconnected the battery for 5 minutes with no prevail, everything is the same...what gives!
Any suggestions are appreciated.
Thanks!
Chevrolet Forum News
Jan 16, 2019 4:38 PM
Sep 19, 2017 8:28 AM
Apr 13, 2017 5:18 AM
Pugly
Jun 19, 2014 7:57 AM
Feb 28, 2014 2:18 PM
