Outside/ambient air temp sensor replacement?
Old Jun 5, 2021 | 4:09 PM
mad max's Avatar
Default Outside/ambient air temp sensor replacement?
The screen shows the wrong temp a lot lately. Suggestions? Replace sensor? I think it’s near the radiator. It’s under $20. Under $10 for a delco. If it’s not hard to get at it seems like a no brainer to just swap it out and see if that fixes it. Anyone know how hard it is to get at? Or a better idea? Temp is often corrected by turning it off and on again.
Old Jun 6, 2021 | 11:21 AM
keep in mind the ambient temp sensor does not always show a live reading. It will have times when it displays old readings until it updates under set criteria.
Old Jun 7, 2021 | 6:04 AM
mad max's Avatar
Default Thanks
Hopefully that’s the problem. Then yesterday the sunroof wouldn’t open. Turned the truck on and off a few times and it started working again. 😳. So much electrical stuff.
CactusVan
10
Aug 23, 2021 5:20 PM
TOMMILTZ
Jul 28, 2019 1:13 PM
linux2
Jul 11, 2014 12:24 PM
Aberry
Jun 7, 2011 11:29 PM
montana suburban
May 11, 2010 5:19 PM
