P0340 after replacing sensor and no start
Old Mar 13, 2024 | 11:53 AM
Gerome's Avatar
Default P0340 after replacing sensor and no start
My wife ran my 2014 Chevy Silverado 5.3 liter out of gas and it would not start back. I had it towed to my house and it was giving me a code for fuel rail pressure sensor. I changed it and the sensor under truck on low pressure line. I measured pressure to hpfp and it was good. I was aware the hpfp goes out often so I replaced it when it still wouldn’t start.I also replaced spark plugs and wires and new battery. It was giving me a P0340 code so I replaced the camshaft position sensor. I cleared code and tried to start truck but it is still just cranking and throwing P0340 code. Is there a relearn code or something tripped that I have to reset for this problem to be fixed. I’m going to check the power on the sensor with a multimeter and make sure the new one isn’t bad but IDK what to do. Any suggestions would be greatly appreciated.
Old Mar 18, 2024 | 1:08 AM
Did you replace with OEM parts?
you should be able to find circuit schematics on charm.li
https://easyautodiagnostics.com/gm/4...-bench-tests-1
it's probably a good idea to perform a relearn using a bidirectional diagnostic tool
PjNewChevy
2019+ Silverado (GMT-T1)
Jul 26, 2023 10:44 PM
mcivatte
Jul 5, 2021 2:20 PM
Guyver's Lab
HHR
Jan 23, 2021 3:08 PM
stanman
May 24, 2013 12:38 PM
dcmoore
Jul 17, 2011 5:24 PM
