Mass Airflow Sensor Trouble
Old Jul 26, 2023 | 11:42 AM
PjNewChevy's Avatar
Default Mass Airflow Sensor Trouble
Hello All,
I just bought a certified ‘21 Silverado (4cyl-Turbo) about a month ago. Since then, my check engine light popped on about a week later giving error code P1101. From what I could find online, I need to clean the mass airflow sensor, or replace it. I cleaned it with Mass-Airflow Cleaner, popped it back in and drove another 600miles, then it popped the same code. I did the same thing again, and another 200mi later, same code. I replaced the air filter and the mass airflow sensor at this point with parts from a dealer. 860mi later, popped the same code.
I can unplug the MAF sensor and plug it back in, and if I restart my car, the check engine light turns off.
What do you think the problem could be?
-my voltage-meter while running the car reads ~12-14v
-the wires do not seem damaged or loose going the the sensor
Old Jul 26, 2023 | 4:39 PM
it's only 2 years old. Isn't this a warranty issue?
Old Jul 26, 2023 | 4:50 PM
measure ground on MAF terminal E, voltage on D
Old Jul 26, 2023 | 10:44 PM
chem_man's Avatar
15 Year Member
You have to remember that the P1101 DTC is telling you that there is an issue with the MAF System - it is not telling you that there is a problem with the MAF sensor.
Hence, you should be looking at the electrical connections, looking for an air leak, checking the air filter for restrictions, etc.
Here is a webpage with more information:
https://www.autocodes.com/p1101_chevrolet.html
And, as mountainmanjoe mentioned, isn;t this a warranty issue? I would just let a dealership's service department handle it since it's a "...certified '21 Silverado..."
Good Luck!
Guyver's Lab
HHR
Jan 23, 2021 3:08 PM
Steverenio
Dec 15, 2017 8:20 AM
stanman
May 24, 2013 12:38 PM
shivy
Cobalt
Sep 27, 2010 5:49 PM
