rattle on cold start
Old Feb 16, 2024 | 7:31 AM
BrettT's Avatar
Default rattle on cold start
Hey everyone, new member here and have a question about an annoying rattle on my 2017 Silverado 1500 WT. It only does it when cold and last for maybe 10 seconds and quits. I can't seem to pin down what it is or exactly where but seems to be under the truck about the back of the trans area. It sounds like a metal flap opening and closing kind of fast but gradually get quiter over 10 seconds. It doesn't always do it either but just about every day when i'm warming the truck up before i go home it does. When warm it never does. I've checked everything i can see and nothing is loose (or i just havent found it yet) so hoping someone else has had this issue and can shed some light on it.
Thanks in advance for any input
Old Feb 16, 2024 | 2:15 PM
look for loose exhaust heat shields
Old Feb 16, 2024 | 5:59 PM
BrettT's Avatar
That was the 1st thing i looked at and all fasterners are tight and it doesn't move or is against anything. This rattle is the exact same every time and quickly starts getting quieter and gone within 10 seconds
Old Feb 16, 2024 | 10:08 PM
what else did you check?
Old Feb 17, 2024 | 9:04 AM
DadRocks73's Avatar
Default Exhaust
I have a 2017 Silverado that had this. It was the inside of muffler. There is some sort of baffle that gets noisy but goes away once it gets a little warm. I upgraded the muffler to a flow master with a little better sound and the noise is gone. Truck sounds better too. This is my guess. I’d take it to a muffler shop and I’ll bet they will tell you the same.
Old Feb 17, 2024 | 4:01 PM
So shaking/bumping the exhaust system should confirm that fairly quickly
Old Feb 17, 2024 | 4:21 PM
DadRocks73's Avatar
Default Maybe so
It may but I couldn’t reproduce the noise when I tried with my truck. I called a muffler shop and they said it was a common issue inside the factory muffler. Replaced last year and no more rattle.
rmelectricalsvc1
May 11, 2018 8:05 PM
SuburbanSS
Jan 8, 2013 3:23 AM
Roeder
May 15, 2012 4:11 PM
cartitles
Oct 2, 2009 10:24 AM
mSub
Apr 21, 2009 9:56 AM
