service 4WD issues
Old Apr 5, 2024 | 5:47 PM
MartinM's Avatar
Question 2014 1500 truck wont shift out of 4X4
Hi guys i have 2014 chevy 1/2 ton truck and it wont switch out of 4 wheel drive, the indicator light on the 4X4 shifter **** only turns when i turn the **** to auto, nothing else happens no matter where i turn it to....
No shifting sounds or nothing, any idea what could be wrong ? or anyway i can manually shift it to see if its just stuck or something?
thanks
Old May 23, 2024 | 5:39 PM
MartinM's Avatar
Exclamation service 4WD issues
hi i have a 2014 chevy Silverado 1500 LT with a 4.3l I'm having 4wd issues, there is a service 4wd message on the dash and i am constantly getting 3 codes from the TCCM C0306, C0321, C0396...
and i have already checked the obvious fuses, 10volts at the encoder motor, i replaced the 4WD switch and the encoder motor already, still have the same codes and cant hear any audible noises from the shift motor.
wondering if any of yall have have the same problem and what it would take to get it fixed.... other then what I've already done obviously lol..
thanks.
Old May 23, 2024 | 5:45 PM
Do you have the MP162x (RPO NQF) or MP302x (RPO NQH) transfer case?
here are all the diagnostic steps for C0306
https://charm.li/Chevy%20Truck/2013/...0Charts/C0306/
C0321
https://charm.li/Chevy%20Truck/2013/...0Charts/C0321/
C0396
https://charm.li/Chevy%20Truck/2013/...0Charts/C0396/
electrical schematics
https://charm.li/Chevy%20Truck/2013/...ansfer%20Case/
Old May 27, 2024 | 11:03 AM
MartinM's Avatar
C0321
C0396
i have a MP3024 automatic 2 speed transfer case.
Old May 27, 2024 | 11:57 AM
MartinM's Avatar
how do i know if i have a bad T case control module? are there any tests i can do to check that out without replacing the control module.
Old May 27, 2024 | 2:10 PM
By following the diagnostic steps in the links I posted. The tests are there.
The site also has symptom related procedures:
Dawg77
1988 - 1998 (GMT400)
Jan 11, 2024 8:25 PM
QuercusE36
Jun 9, 2019 8:11 PM
karensue1
Feb 5, 2018 9:55 PM
Rmatt34
Dec 29, 2012 7:25 PM
jutgin
Avalanche
Mar 21, 2011 4:25 PM
