Truck won't move in reverse in extreme cold
Old Dec 20, 2022 | 9:14 AM
ti30xb's Avatar
Default Truck won't move in reverse in extreme cold
Hi all,
As the topic says, in extreme cold (-20 celcius and colder) my truck will properly shift to reverse - but unless given extreme amount of throttle will not move. I have the 5.3L and I believe it is mated with the 6L80 tranny. Truck has 198,000 KM and I saw on the work history the torque convertor was already replaced once at 135,000 KM (which I thought was a little unusual) - so the current torque convertor only has 63,000 KM on it.
If I let the truck idle for 20 minutes until the transmission fluid temp reaches around 5 degrees or warmer, things move fairly better... but not practical.
I just did a dealership fluid flush and fill on the tranny and transfer case hoping the issue would go away, but no luck.
Any thoughts where to begin? Thanks!
03 silverado 843
Apr 18, 2021 3:30 PM
03 silverado 843
Apr 18, 2021 3:05 PM
kinghenry
2007 - 2013 (GMT900)
Aug 18, 2018 11:50 AM
ussva
Mar 18, 2010 10:07 PM
five20too
May 10, 2008 11:05 PM
