VIN Decoder Questions
Hi. new to the forum and hoping I could get some help on the VIN decoder tool. it has a lot of good information, but the problem is too much information.
I have a 2014 Silverado 1500 2WD double cab with the 5.3 V8 and I am trying to sort out the towing capacity so I know what size camper I can buy.
The VIN decoder has a ton of information, but when it comes to the towing capacity it has multiple options and I don't know which applies.
So, with all that confusion, I figured I would go look in my owner's manual but that's clear as mud too. It has multiple options as well and I simply am not sure what it can be.
I've tried googling for information, but nothing is clear.
Does anyone know how I can figure this out for my truck? Or where I can look? If not, I guess it's a trip to the dealer.
Thanks in advance!
Gross Vehicle Weight Rating Cap 7200, 7000, 6900 lbs 6900.0 min 7200.0 maxGross Combined Wt Rating 16700, 15000, 12000, 11000 lbs 11000.0 min 16700.0 max
Dead Weight Hitch - Max Trailer Wt. 5000 lbs 5000.0 min 5000.0 max
Dead Weight Hitch - Max Tongue Wt. 500 lbs 500.0 min 500.0 max
Wt Distributing Hitch - Max Trailer Wt. 11500, 9900, 6900, 6000 lbs 6000.0 min 11500.0 max
Wt Distributing Hitch - Max Tongue Wt. 1725, 1485, 1035, 900 lbs 900.0 min 1725.0 max
Fifth Wheel Hitch - Max Trailer Wt. 11500, 9900 lbs 9800.0 min 12000.0 max
Fifth Wheel Hitch - Max Tongue Wt. 2875, 2475 lbs 2450.0 min 3000.0 max
Maximum Trailering Capacity 11500 lbs 11500.0 min 11500.0 max
Thanks in advance!
Thanks in advance!
Thanks in advance!
Vin Decoder for USA
Using this tool, you will be able to find out more about the car you are interested in and its history.
Run a VIN check With Chevy Vin Decoder
Google SB-10067329-9133.pdf, Click on "
Program Bulletin - NHTSA, This should bring up TSB 14212.
This will give you trailer and gross combined weight ratings (GCWR), based on what cab and box configuration, engine and gear ratio you have. This is an update for your owners manual
Hope this is helpful.
<!--td {border: 1px solid #cccccc;}br {mso-data-placement:same-cell;}-->check the history of an old car. <!--td {border: 1px solid #cccccc;}br {mso-data-placement:same-cell;}-->How to check Toyota VIN Decoder
will be the best and most free option if someone needs a detailed history. you can use this site too for chevy https://chevytrucks.org/chevy-vin-decoder/
Matt_pound
May 22, 2013 7:45 PM
