Wet floor
Old Jul 7, 2018 | 7:34 PM
Dwall02's Avatar
Default Wet floor
Hey guys I think my ac is leaking water into my passenger floor how can you I fix this ?2016 2500hd
Old Jul 8, 2018 | 4:47 AM
oilcanhenry's Avatar
When you stop the vehicle with the AC on, water should be draining on to the ground. Sounds like the drain is plugged up to me.
Old Jul 8, 2018 | 7:23 AM
Dwall02's Avatar
Thanks for the reply. I have checked that and it’s dripping pretty good ? I was told maybe the heater core?
Old Jul 8, 2018 | 7:53 AM
Is it coolant or water? If it is coolant then it is the heater core.
Old Jul 8, 2018 | 11:33 PM
Should be able to taste if its water or coolant. Man, I sure hate taking apart the dashboard to replace those things!
Old Jul 14, 2018 | 10:00 AM
Dwall02's Avatar
It’s water. Took it to the dealer and the case that holds the evaporator coil is busted ? Truck only has 30000 miles on it ?
Old Jul 14, 2018 | 12:09 PM
Rednucleus's Avatar
Still under warranty?
Old Jul 14, 2018 | 5:27 PM
Dwall02's Avatar
Yes it’s under warranty 31000 miles
