2014 Silverado AC Problems Already?
#311
Same Here!
Bought a 2014 Silverado Z71 Crew Cab just under 4 years ago, and suddenly encountered the same air conditioning problems described above. Works fine one day, the next only warm air coming form the vents. Very frustrated to have the AC go out on a vehicle this new. Would love Chevy to address this issue with a recall as it seems a common complaint. Vehicle is currently at a dealership for diagnostics. Warranty is past
#312
So after a ton of research on this forum and generally all over the web I see I'm not alone. 2014 LTZ bought in Nov. 2014 with 42K on it. AC out. Dealer where I bought says that it's a workmanship problem with the welds at the compressor to the fixed hoses. So in my common sense thinking hey this should be a recall since it looks as though the AC on the 2014s were pout in like crap. Nope sorry buddy you owe $1200 to get it fixed. If you want a recall contact GM!!!! Are you kidding me. I have to assume with the FB page and countless people emailing or contacting GM that they would do something...oh wait thats my common sense thinking. If it's not a mandated safety issue then no recall...which means if you can't find fault to GM for being liable for knowingly hurting another vehicle or life NO RECALL. Absolute BULL****! I've owned a Chevy for over 25 years and my 02 with 285K miles lasted better then this new one...no tune ups, no tinkering, no AC failure, NOTHING! This will probably be my last Chevy after this one is paid off.
GM You should be ashamed that you won't take responsibility for workmanship issues.
#314
Same here too
#315
Compressor seized up
just got mine back 12-13-17 from the dealer 36,050 miles and $1376.00 along with oil change and tire rotation.. Burnt the belt completely in half. THIS IS TOTALLY UNACCEPTABLE!!!!!!!!!!!!! I new I should have keeped my 1999 2wd, this 2014 is JUNK!!!!
#317
Same trouble. 42,000 miles condenser cracked. This is for sure a defect. There is no way this should crack in a weld. Lots of $$ out of my pocket. Now it blows hot air some days and cold air other days. It is 97F today, and my 8 month old granddaughter is pretty sure it's too hot to ride with me.
VERY frustrated.
VERY frustrated.
#319
Ac is blowing hot air
ok so apoearantly I’m the latest victim in the 2014
Silverado ac condenser debacle. Come on Chevy, there’s thousands of people having these issues. Y’all need to fix this! I paid a lot of money for this vehicle for the ac to die on me now with the truck only being less than 4 years old. And $1200 at the dealer to fix it is a spit in the face.
#320
My 2014 Silverado has A/C issues. Blowing hot air...really bad condition when I have a black truck and its in the 80's. Took the truck into the dealer last week and paid to have the diagnostic done. It came back with a recommendation...Rec. AC compressor hose and nec. parts....$595.00 The advisor stated they ran a pressure test with dye and found a leak in the hose. They told me it wasn't covered and tried contacting my extended warranty company and they said they do not cover hoses. Wow....my 2003 Tahoe has had a service and recharge of freon one time in 14+ years...and its a dual system (front and rear). when I inspected the lines my self i could not find any green dye around or on any part of the A/C lines/hoses.!?? Not sure why its not covered and/or if this is a serious problem with these hoses/lines (2104) why a recall or some service notice been put out about this issue. Any ideas or help would be appreciated.
JTravis
JTravis
