2019 Silverado 4x4 warning and parking brake help
Old Jan 24, 2023 | 7:08 AM
1BadMoFo288's Avatar
Default 2019 Silverado 4x4 warning and parking brake help
Hi All,
Last weekend I had to use 4x4 in my truck, shifted into and out as normal. While in 4x4, I did notice that the front wheels were extra choppy on tighter corners. I know all 4 x 4's do this, but honestly I don't remember it being this bad.
Anyway, shortly after I got a message stating (service 4x4.)
This is when I then noticed, that when I put the truck in drive or reverse, it doesn't start in motion like it used to. I have to give it gas to like "break it free."
Then yesterday I got a new message (service 4x4 is still on also) that said "releasing parking brake" but I never turned the brake on. It keeps doing this since.
Any thoughts or feedback as to what it could be? Hoping just a failed sensor or something.
Thank you for any help.
Old Jan 25, 2023 | 11:08 AM
Well, I didn't hear anything on the forum so I went ahead and made an appointment for tomorrow. Man I hope this isn't pricey. The issue with the parking brake keeps happening, every time I get into the truck is is engaged and will not release with the button, I just have to give it a little gas.
Old Jan 27, 2023 | 9:17 AM
Problem fixed, $92.00. Very excited about that as I thought it would be much more.
Codes were C11B3, P189A, C0277, C0297. Performed Range Actuator Correlation Learn, all codes moved to history, running correctly now.
Old Feb 27, 2023 | 9:22 PM
markyezy's Avatar
So what ended up needing to be replaced at the shop?
Old Mar 1, 2023 | 6:50 PM
if you have 4x4 and not AWD...its a part time 4wd system not meant to be run on dry pavement (4auto the exception)...that bind on turning is very stressful on the tcase
JunoAF
Jun 20, 2015 8:15 AM
Fishinfooleric10@aol.com
Dec 2, 2012 8:54 PM
IROCmabe
Sep 27, 2012 9:55 AM
chevymaniac
Nov 20, 2008 5:10 AM
CREEKROW
Dec 11, 2005 12:11 PM
