I am installing an LED light to add to my Western Snow plow. I am looking for a connection point under the hood, that is switchable [on and off with ignition ] I see a few Not Used locations in fuse block, are they active,, or just blank sockets,, I would like to use these fuse taps,and if I can , just put one in a not used socket,,,,, but,, is ther power or tabs in them to grab the fuse holder ?
if its a 2500 use the upfitter fuse block. this connects to the switch bank in the vehicle. 1500 are not the best choice for plow mounting.
. No worries, it is a 2500 with plow package, are saying to use the fuse panel in the cab ?
If so, drivers or passenger side? The LED light has a relay so i mount d that under the hood,, hoping to find a hot spot in the fuse panel also under the hood,,,,,
