2022, 2500hd, cooling lines rubbing
Old Nov 2, 2022 | 10:17 PM
JRT600's Avatar
Default 2022, 2500hd, cooling lines rubbing
I read a post the other day, stating that the Transmission and Engine Oil cooling lines, maybe rubbing. So, I crawled under the truck. Sure enough, the cooling lines from the transmission to the radiator, were close enough, to maybe rub. I did find the engine oil cooling lines to the radiator were rubbing in one area, slightly. Also, the point where the transmission and engine oil cooling lines crossed, were very close. So, I took several wire ties and put on the lines, where they either rubbed or were very close, to keep the lines from rubbing. I will watch these lines for issues.
Old Nov 3, 2022 | 12:35 AM
oilcanhenry's Avatar
That'll work, or buy some of those plastic hose/wire covers to fit.
Old Nov 4, 2022 | 2:38 PM
chem_man's Avatar
15 Year Member
As oilcanhenry said, use some tubing. I have used fuel line tubing, slit it lengthwise, slip it over where the area where it could rub/wear through, and then secure it using a couple of zip ties.
Good Luck!
Steve97Chev
1988 - 1998 (GMT400)
Sep 28, 2020 9:31 PM
elleonlp
Sep 11, 2017 8:25 PM
NoFear50
Sep 16, 2015 7:13 PM
usmarine0905
Nov 25, 2011 4:30 PM
dand66
Nov 1, 2010 11:26 AM
