Airflow issues
Old Jun 9, 2024 | 3:45 PM
SS08LTZ's Avatar
Default Airflow issues
Hello all. 2019 2500HD LT Z71.
AC works great but air is coming out of the floor and dash vents whether I select split or dash. It will change to floor only or defrost only and work perfectly. But on dash only or split dash/floor it blows like it's on split.
Anyone have this issue before? I'm assuming some diverter motor but again works perfectly on defrost or floor only.
Any help would be appreciated!
Old Jun 9, 2024 | 9:21 PM
chem_man's Avatar
15 Year Member
It sounds like the mode actuator is not working right. Are you hearing any clicking or ticking in the dash when you switch from floor to dash to defrost? Clicking/ticking is a sign of a bad actuator.
OR, the panel it moves is broken.
You really need to see how the HVAC system is put together using a factory service manual in order to be be certain.
This resource might be of assistance:
https://mcdowellpubliclibrary.org/chilton-auto-repair/
Good Luck!
Old Jun 9, 2024 | 9:53 PM
SS08LTZ's Avatar
Good Luck!
Thank you. No there is no clicking sounds and as I said when I select floor or defrost it works perfectly. Just no difference between split when selecting split or dash.
S
Old Jun 10, 2024 | 11:28 PM
chem_man's Avatar
15 Year Member
Something is definitely amiss. Time to visit an HVAC shop that has the correct testing tools.
sg29651
Aug 30, 2011 10:39 AM
if1ops
Aug 4, 2010 4:41 PM
cujo8
Oct 28, 2008 11:02 AM
chevydog83
Aug 21, 2008 9:29 PM
life24523
Apr 15, 2008 3:19 PM
