Auto window rollup feature failed
Old Aug 15, 2022 | 5:51 PM
Namelama's Avatar
Default Auto window rollup feature failed
My driver's window on our 2019 Silverado, Crew, LT, automatically rolls down after pulling the auto up switch. If you hold the switch up until the driver window closes, the window will stay up. Riverside Chevrolet diagnosed the problem as a bad window module, replacement part alone is $548. Anyone else have this problem and what was the fix?
Thanks for your input!
Old Dec 6, 2022 | 4:27 PM
mrmeyer4irm's Avatar
Doesn't look like anyone answered your question. I have the same problem on the same model. When I click the Auto-Up it goes about half way and then goes back down. If I do this multiple times, sometimes it will make its way all the way up but most times it doesn't so I have to hold the button until it is all the way up. What did you do to correct it, was it covered under your warranty or did you pay to have it fixed. It's more of a nuisance than anything.
Old Dec 12, 2022 | 11:11 AM
Robby368's Avatar
Following. I found a similar vid for 18-older about removing a particular window motor fuse while it's running and this should reset it. The 19+ fusebox is different and I have yet to find the solution. I know for sure I'm not giving a dealership 500+ for the fix.
Edit: here is the vid link. Can someone find this similar fuse for the 19+?
proshadessd
Dec 23, 2021 12:18 AM
MastahMan
Trax
Jun 10, 2018 4:30 PM
justin69
Feb 28, 2015 2:54 PM
biged0412
Nov 24, 2014 9:49 PM
98greenventure
Apr 1, 2007 3:15 PM
