Can I upgrade the AC inverter
Old Feb 29, 2024 | 8:16 AM
  #11
Happle98's Avatar
You just ignored everything that chemman JUST explained.
510 watts @ 12V = 42.5A
I think you need to leave this to a professional to install.
Old Feb 29, 2024 | 8:19 AM
  #12
Your truck runs on 12V. You need to enter 12V.
That's 50 amps with efficiency losses.
Please let someone else do it so you don't set fire to your truck.
Old Feb 29, 2024 | 9:20 PM
  #13
Originally Posted by Happle98
Google says different
If you want to trust Google over actual advice from an automotive forum, from people with experience installing such systems , then go right ahead. But I don't know why you asked then. Not even auto insurance will help you, so at least have good life insurance.
Old Feb 29, 2024 | 10:09 PM
  #14
Happle98's Avatar
Was originally looking for guidance on doing this task. Steps on what to do, not "what not to do"
Old Feb 29, 2024 | 10:14 PM
  #15
you were given guidance and told exactly what to do, and your response was that you knew better. Good luck.
Old Mar 1, 2024 | 3:46 AM
  #16
hanky's Avatar
Sometimes there may be more than one way to get things done and still do it safely, but one wrong move is all it takes to do a lot of damage.
From that school of hard knocks, we learn some videos are not that accurate. Keep in mind anybody can put a video on the net whether it is right or not !
A good basic background of electricity is easy to obtain and will serve for a long time, something to consider.
Old Mar 1, 2024 | 9:03 PM
  #17
chem_man's Avatar
15 Year Member
Here is a simple mathematical equation you can use:
watts (in or out) = (Vin)*(Ain) = (Vout)*(Aout)
(Ain) = ((Vout)*(Aout)/(Vin))
(Ain) = ((120)*(4.25)/(12))
(Ain) = 42.5
where Ain equals Amps in
Aout equals Amps out
Vin equals Volts in
Vout equals Volts out
Old Mar 2, 2024 | 6:35 PM
  #18
Happle98's Avatar
(Ain) = 42.5
Vin equals Volts in
that makes more sense. Thank you for making it more understanding.
Old Mar 3, 2024 | 8:04 PM
  #19
chem_man's Avatar
15 Year Member
You are quite welcome!
Since nothing is 100% efficient, the Watts in will always be larger than the Watts out. By how much depends on multiple things such as the efficiency of the inverter, the ability of the inverter to dissipate the heat generated by it's components, the size of the wires carrying the current, the quality of the wires used to carry the current (are the wires pure copper or are they copper clad aluminum), how well the connectors used to terminate the wires are soldered or crimped, etc. Hence this is not a trivial endeavor.
Toddmike322
Jul 13, 2022 10:12 AM
Ryan Bonser
Mar 15, 2020 1:44 PM
JMF
Aug 22, 2019 10:48 PM
Johnny Mayday
2019+ Silverado (GMT-T1)
Jun 25, 2019 5:47 PM
Gravydog316
Corvette
May 2, 2018 7:39 AM
