Oil Issue
Old Dec 2, 2024 | 2:10 PM
TicketP1's Avatar
Default Oil Issue
I have had to add oil after the last two oil changes. I just assumed that the first time, they just didn't fill it all the way. The second time, I was curious because the second oil change was at the dealer. I had it changed the other day, and the place told me that I might have an oil displacement issue. Has anyone else had this issue? I have no leak, and I don't think it's burning oil, but where is the oil going? Also, if I just keep oil in it, is there any long-term damage that can be done? Thanks for any input
Old Dec 2, 2024 | 4:45 PM
Rednucleus's Avatar
If your oil level is going down over time, that says leak or using/burning it to me. Please post your vehicle specs. I have not heard of "oil displacement issue".
Old Dec 3, 2024 | 6:26 AM
TicketP1's Avatar
2021 Silverado LTZ 5.3 4WD 76,000 miles.
I also have never heard of this. I have no leaks, and I would think if it was burning, I'd smell it or see smoke. I'm at a loss
Old Dec 3, 2024 | 9:40 AM
Rednucleus's Avatar
You can use oil and see/smell no evidence. How many miles do you go before adding a quart and how many miles on the motor?
Old Dec 10, 2024 | 6:34 AM
TicketP1's Avatar
I am not sure on how many miles before I have to add. low oil light came on and I had to add 3 quarts both times. I am watching it now. So far not needing to add but I have not driven truck a lot since last oil change. I have 76K on the motor.
Old Dec 11, 2024 | 10:22 AM
chem_man's Avatar
15 Year Member
Do you routinely check the oil level by pulling the dipstick? Say like once a week, every time you get gasoline, the first Monday of the month?
You need to do this so as to not run the engine too low on oil.
Old Dec 11, 2024 | 10:32 AM
chem_man's Avatar
15 Year Member
Just as an FYI, I check the oil level in my vehicles weekly, If I am on a trip, I will check the oil level either daily or after filling up with gasoline when I stop for gas.
Susie96
May 2, 2024 4:51 PM
Chevythunder97
Trax
Nov 13, 2023 1:09 PM
P0well
Apr 16, 2023 4:34 PM
bananas
Oct 24, 2022 2:24 AM
Flipg8tor
Oct 20, 2011 10:23 AM
