Transmission temperature
Old Jul 23, 2024 | 1:16 PM
Cbpat's Avatar
Default Transmission temperature
I have a 23 Silverado LT with a 2.7L and 8 speed transmission. Truck runs great, no problems but, I wonder where the transmission temperature is supposed to be at. I live in Florida so the temperature outside is in the mid 90’s during the day and the transmission temperature can run as high as 209. I’m not pulling anything and am wondering if that is too high, if so should I have a transmission cooler installed and what’s involved with that?
Old Aug 29, 2024 | 8:13 PM
MarkBB's Avatar
I have the same motor and transmission. I was having problems, so I was watching my tran temp. The highest I seen mine go way 225. normal driving it would go to 205 pretty quick. That is in Pa.
Old Aug 29, 2024 | 9:17 PM
Rednucleus's Avatar
Is a trans temp gauge standard equipment theses days? If so, where do I find it in our 2020 Tahoe?
Old Sep 5, 2024 | 8:09 AM
Rocket67's Avatar
Mine pretty much stays under 200 (usually way less) and I am in Texas. I started watching after I saw this thread. I will be pulling a camper in the next couple of months, will note temps then and post back.
Old Sep 5, 2024 | 9:00 AM
jfmorris's Avatar
Well, all I can compare your transmission temps to is my son-in-laws 2008 GMC Denali 6.2L with the 6L80 transmission (6 speed). The DIC (Driver Information Center) can show the transmission fluid temp. He was TOWING my Subaru Impreza on a U-haul car hauler through moderate grades in the mountains and the highest we ever saw the transmission get was 180ish, and on the flat it would drop to about 160. That is towing over 7000 pounds, the weight of the car + trailer, on a 85 degree day in May of this year. When not towing anything, just around town, I think he runs below 160. This is with the stock cooling on that particular vehicle, which was decked out with every factory option GMC offered on the 2008 Denali (basically an upscale Suburban).
I would expect an 8 speed transmission to run at lower temps at cruising speeds without towing anything, but that's just me.
Termite72
2007 - 2013 (GMT900)
Jun 20, 2024 2:54 AM
Thomas Neels
Jan 16, 2022 2:22 PM
cannibal carl
HHR
May 20, 2021 10:08 AM
muntaser
Jul 18, 2017 7:02 AM
