Astro 1985-2005
Platform: M-Body
1999 Chevy Astro rough idle in drive
Old Oct 18, 2011 | 12:02 PM
t2baldwin's Avatar
Default 1999 Chevy Astro rough idle in drive
I have a 1999 Chevy Astro with 172K miles. The van has started to rough idle when in drive sitting at stop signs/traffic lights. It smooths out when in Park or neutral. Under acceleration, the van runs fine. Replaced plugs, wires, cap & rotor. Still have same problem. No codes are being pulled when checked.
Any ideas/hints/suggestions on what the issue might be?
Thanks.
Old Oct 22, 2011 | 9:19 AM
ihatemybike's Avatar
Might be dirty injectors. The CFI sysetm is known to gunk up with time. You can try a Seafoam treatment into the throttle body. If that fails GM has some heavy duty stuff called GM Fuel System Treatment Plus, little pricey, but works great.
Old Oct 22, 2011 | 10:36 PM
MDTAHOE's Avatar
Professional Mechanic
Sounds like sagging motor mounts
Old Nov 3, 2011 | 3:20 PM
jelectrico's Avatar
Air filter maybe.
Old Feb 8, 2012 | 1:57 PM
hdtrc's Avatar
I just swapped out the intake gaskets on my '02 and when I pulled out the distributor, the gear at the bottom of the shaft was heavily worn and introduced a lot of play. It confuses the ECM. I just ordered a replacement gear...seems to be a popular part to go bad.
Old Feb 8, 2012 | 2:07 PM
chrisKizi's Avatar
Thanks.
SO did you ever figure it out?
macmommy
Apr 22, 2020 1:23 PM
Sethyates72
Feb 1, 2014 7:53 AM
futrrokstr90
Dec 24, 2011 8:38 AM
dbapcp
Apr 25, 2008 4:30 AM
