Astro 1985-2005
Platform: M-Body
2004 Astro 2wd no 4th gear
Old Mar 23, 2024 | 7:45 PM
erubin2000's Avatar
Default 2004 Astro 2wd no 4th gear
2004 Astro, 2WD. Vehicle automatic shifts fine except does not shift 3rd->4th unless i play with the accelerator. Fluid looks perfect, color, smell and level are perfect. Shall I drop the pan and change 1 or more solenoids. No CEL.
Old Mar 23, 2024 | 8:23 PM
How many miles on it?
Solenoids might be a waste of money if the trans is plum wore out.
Old Mar 24, 2024 | 2:43 AM
erubin2000's Avatar
210k miles. Does anyone have troubleshooting advice? Fluid is in excellent shape and has not had a recent fluid change. Can a solenoid cause just one shift to fail? Is that possible with 2 solenoids controlling 4 gears? Or would a problem with a solenoid prevent two shifts to fail? I only lost 4th. Anything else to check/replace with pan off? Willing to spend $20 on a solenoid, $30 on filter and pan gasket and maybe $35 on trans fluid. Waste 2 hours on my labor. But not if you are sure it can’t be the solenoid
Old Mar 24, 2024 | 1:46 PM
A transmission shop would have to look at it and run some diagnostics to see. But he'll probably says the same thing : it's not worth putting money and time into a transmission with that many miles. Solenoid failures usually throw trouble codes.
Old May 29, 2024 | 2:27 PM
Dexter77's Avatar
As it happens, I am experiencing the same issue: difficult/inconsistent shifts to 4th gear (TC lockup).
2001 Astro, 80K miles, RWD
After weeks of head scratching and sleeping on it, I have decided that my issue is a restricted CatCon.
It's the original, as far as I can tell.
I am getting the same behavior. I get the P0101 DTC in strong headwinds and going uphill. And cannot hold speed on steeper hills.
As purchased, it had the CSFI (poppets) fuel injection spider, and I was having hard starts and poor mileage.
When I replaced it with the newer MPFI fuel injection spider, I found the intake was full of soot and grime. My TBI throttle plate's leading edge was COVERED in black crud! I believe unmetered fuel was making it run very rich, washing oil from the rings and dumping unburnt/incompletely burnt gas into the exhaust to be reinjected via the EGR valve.
I have ordered the new CatCon, which is a huge piece, includes Y Pipe and TWO converters in series.
I will return to say for certain if this was the root cause.
Walther-Anna Von Einik
Astro
May 29, 2024 2:39 PM
Tom Steinhauer
Aug 4, 2013 2:42 PM
dmoore
Dec 7, 2011 9:02 PM
vulcan
Astro
Feb 24, 2010 9:46 PM
BigFish246
Astro
Jul 19, 2009 7:14 AM
