Astro 1985-2005
Platform: M-Body
2005 astro 265k.
Old Jan 26, 2019 | 7:16 AM
Scottawesomenator's Avatar
Default 2005 astro 265k.
Had starting issue 2 months after 3 days of not driving it. Changed the cap and rotor. Started and ran for 2 months. Last monday after not driving it for 2 days. Again wont start. Grrrrrrr. Popped cap and cleaned with brake cleaner. Wont start now
Old Jan 26, 2019 | 7:39 AM
Are you getting fuel? Do a fuel pressure check to find out. Spray some starter fluid into the throttle body and see if it runs for a few seconds. If it does then you will need a fuel pump.
Old Jan 26, 2019 | 12:41 PM
lots of fuel. Lots of crank on the new battery. Out to check power to plugs then coil etc.. i had a 1998 for 11 years. Zero issues. This one seems lemony
Old Jan 28, 2019 | 8:07 AM
Default 11.56 v at coil output before cranking, 10 v during cranking, is the coil dead
11.56 v at coil output before cranking, 10 v during cranking, is the coil dead?
could the crank position sensor cause this?
Old Jan 29, 2019 | 7:29 AM
INSTALLED NEW COIL, SAME NUMBERS, GRRRRRR, IS THERE ANYTHING ELSE BETWEEN THE KEY, THE BATTERY, THE COIL AND THE DISTRIBUTER, I KIND OF NEED THIS NUISANCE TO BE WORKING. oldchevy?
Old Jan 29, 2019 | 7:36 AM
Yes the crank sensor could cause your problems. Is there a check engine light on? If so what are the codes?
Old Jan 29, 2019 | 7:44 AM
Engine light is on, no codes
Old Jan 29, 2019 | 9:09 AM
Did you check it with a code reader? Autozone or Advance Auto will read the codes for free if you can get it there.
Old Jan 29, 2019 | 9:27 AM
Yup, i have a code reader, i will acquire a crank sensor and try that, looks super easy to get at
Old Feb 6, 2019 | 8:27 AM
So, i have changed the coil, cam position sensor, coil, cap and rotor and crank position sensor, still zero spark, grrrrrrrrrrrrr
