Astro 1985-2005
Platform: M-Body
89 astro running rough while in gear idling
Old Oct 25, 2010 | 11:32 AM
jimbo51565's Avatar
Default 89 astro running rough while in gear idling
i hava an 89 astro and the engine while i am at a stop the engine will run really rough but normal acceration it does fine i have put plugs wires cap and rotor in already replaced all of the bad vaccum lines and coolant temp sensor(one that sends signal to the ecu) oh and someone before i owned it disconnected the egr valve and jb welded the port on it shut and suggestions on where to go next?
Old Oct 26, 2010 | 8:15 PM
Overnite's Avatar
I think I would suspect a leaking injector. Pull your plugs and look for one that is burning too rich. Just an idea.
Old Oct 27, 2010 | 11:49 AM
jimbo51565's Avatar
checked those and do not seem to be leaking at all
Old Oct 27, 2010 | 5:17 PM
Overnite's Avatar
Maybe you should get the rid of that bad EGR valve and replace it with a new and see if that makes any difference.
Old Oct 27, 2010 | 6:55 PM
Keyman's Avatar
hello i have a 2000 astro
my van was shaking the hole dash in gear at idle
but it ran fine off idle
i replaced both motor mounts and the tranny mount
now it is smooth
i had thought it was running ruff
but the shop i took it to showed me
he jacked up the motor and the shaking stopped
hope this may help
Old Nov 1, 2010 | 8:40 PM
jimbo51565's Avatar
i tried to replace it and did not change too much my motor mounts looked to be in really good shape i could not hardly move the motor at all any other suggestions
Cowboy93
Oct 12, 2019 8:32 PM
motoxer4533
Cobalt
Feb 5, 2016 5:24 PM
Chevygurl87
Oct 9, 2013 4:37 PM
timdogg1313
Apr 29, 2009 11:31 PM
sprusgoose
Dec 4, 2006 1:46 AM
