Astro 1985-2005
Platform: M-Body
97 astro
Old Oct 19, 2011 | 1:46 PM
stevejohnson48's Avatar
Exclamation 97 astro
I have recently acquired a 97 astro that has a steering & brake problem,the guy says he was driving down the road and he noticed that his steering started to get tight,and then his brakes went out the thing turns like a tank,the belt is in tack,and the fluid levels are full,any body no a remedy for this situation ?????
Old Oct 22, 2011 | 9:12 AM
ihatemybike's Avatar
Sounds like the power steering pump is going out. Astros run the power steering and brakes (hydro boost) via the power steering pump. Fairly straight forward replacement.
Remove air box
Remove upper fan shroud
Remove fan
Remove lower fan shroud
Disconnect hydro lines to power steering pump
Unbolt pump
Reverse to install.
Fill the power steer reservoir.
Bleed the power steering system by running the engine and slowly turning the steering wheel lock to lock 10 times. Checking the reservoir level about half way through. Best to due this with the front wheels either raised or sitting on two layers of cardboard.
Old Nov 3, 2011 | 3:18 PM
jelectrico's Avatar
Aron can it be the hydro booster itself?
Old Nov 3, 2011 | 10:35 PM
I'd suspect the booster if it was only the brakes having problems. I've never had to replace a booster, but I've replaced power steering pumps a couple times.
HeatDet
Astro
15
Jun 9, 2010 9:18 PM
93Miata
Astro
Mar 1, 2008 1:49 AM
