97 Astro bad vibration when applying on brake pedal and steering wheel
So I have this astro van that came in customer said it just started happening as he was coming down to the shop.
Symptoms: Very loud noise/back fire vibration from the brake pedal like clunking noise, Also when turning the steering wheel left to right and right to left hear the same noise.
Now i've looked at it and I felt bad vibration from the power steering line from the hydraulic booster to the power steering pump. Then I felt vibration on the pump not as bad as the vibration from the line. Would replacing the power steering pump fix this problem since everything runs off from the hydraulic booster? Or would a 1 simple line can cause this problem?
I would like to get more information for the experience owners!
Thank You for your time.
How loud? What does engine speed do for it?
Grumpy moans and groans and is hard to turn at idle, but if I cover the brake and give it a little gas to build pressure the steering get easier and the brake pedal becomes more solid. (I really should replace the PS pump.)
I've never heard of a PS line clogging.
next2nothing000
Oct 10, 2021 9:25 AM
Auto Angel
Aug 5, 2010 3:12 PM
