Astro 1985-2005
Platform: M-Body
Astro Window Opens Half Way
Old Mar 17, 2011 | 1:02 PM
mejung's Avatar
Default Astro Window Opens Half Way
The driver side power window on my 2000 Astro opens half way. The motor keeps running, but the window refuses to open the rest of the way.
The window will close, but after closing, the motor continues to run until I remove my finger from the button.
Any help would be appreciated. Thanks!!
Old Mar 30, 2011 | 10:28 AM
wile e coyote's Avatar
knowing absolutely nothing about astros in particular, I'd have to say the likely culprit is the felt lining in the window channels has worn out or turned to goo. It is a common problem in all older vehicles.
Old Apr 13, 2011 | 7:03 AM
djoker04's Avatar
Sounds like it's not catching (THE TEETH).......
Before replacing the motor (Still a possible Culprit) take the panel off (EASY) pull the liner down and inspect the linkage and motor as you open and close. I replaced the Passenger some months back....very easy to do...now my Drivers side is acting up....If I hold on to the button too long while lowering it, it on't go up right away.....it's like a power drain...have to wait for it to (RECHARGE...so to speak) I'll be replacing that one soon. But to be on the safe side order a motor and replace it anyway..mine is a 99.....no harm no foul....
Old Aug 1, 2012 | 12:18 PM
Stefko's Avatar
I would just order a replacement motor. I had similar issues with my drivers side motor. $50
crateampsrock
Uplander
Jun 14, 2012 7:03 PM
zack_novak
Jul 11, 2011 2:51 PM
dj pc era
Astro
May 27, 2011 9:57 PM
mjkxxl
Sonic (Aveo)
Mar 21, 2010 2:57 PM
mrlong
Apr 17, 2007 12:37 AM
