Back door window opens without key
I have locked every door, turn left right, button pressed...
checked fuse...
and nothing... door opens without key....
it only locks when I remove the fuse.. any help.?? thanks
checked fuse...
Official GM Rep
Thank you!
Elizabeth, GM Customer Service
The clasp mechanisms have control rods that extend to a pivot in the middle of the hatch. The actuator is what moves the pivot to pull the rods. Disconnect it from the wiring harness and see if the door latches. Check for voltage from the harness, it should have none when the button isn't pressed.
xrayrep
July 11th, 2014 7:31 PM
davbell22602
March 10th, 2010 8:36 PM
