Astro 1985-2005
Platform: M-Body
Back door window opens without key
Old May 19, 2011 | 9:32 PM
dj pc era's Avatar
Default Back door window opens without key
I have locked every door, turn left right, button pressed...
checked fuse...
and nothing... door opens without key....
it only locks when I remove the fuse.. any help.?? thanks
Old May 20, 2011 | 8:33 AM
Official GM Rep
checked fuse...
I am sorry to hear that you are experiencing issues with your vehicle. Have you spoken with your dealership for a diagnosis? Please let me know.
Thank you!
Elizabeth, GM Customer Service
Old May 21, 2011 | 6:57 PM
dj pc era's Avatar
I'm trying not take it there and fixing it myself...
I currently don't have the funds to shell out cash...
Old May 22, 2011 | 9:13 AM
ihatemybike's Avatar
Sound like something is causing it to get power all the time. Maybe the switch has gone bad. I'd check to see if voltage is getting to the actuator when it shouldn't be.
Old May 22, 2011 | 3:58 PM
dj pc era's Avatar
would it be that?
Old May 24, 2011 | 5:02 PM
The clasp mechanisms have control rods that extend to a pivot in the middle of the hatch. The actuator is what moves the pivot to pull the rods. Disconnect it from the wiring harness and see if the door latches. Check for voltage from the harness, it should have none when the button isn't pressed.
Old May 24, 2011 | 5:31 PM
dj pc era's Avatar
when I remove the wiring harness it latches and closes fully
Old May 27, 2011 | 9:57 PM
dj pc era's Avatar
still around seeking massive help <3
xrayrep
Jul 11, 2014 7:31 PM
mejung
Astro
Aug 1, 2012 12:18 PM
zack_novak
Jul 11, 2011 2:51 PM
mjkxxl
Sonic (Aveo)
Mar 21, 2010 2:57 PM
davbell22602
Mar 10, 2010 8:36 PM
