Astro 1985-2005
Platform: M-Body
Burned valve advice
Old Sep 16, 2010 | 6:09 PM
astroclyde's Avatar
Default Burned valve advice
Just FYI this is also posted on AstroSafari - thought I'd try this forum too.
I just pulled the head off my 98 Astro AWD and found that 1. the exhaust valve is damaged and will not seat and 2. the piston is (strangely) slightly scored from where the broken valve must have been hitting it. In spite of this slight valve/piston damage, all the car had before this work was a very rough idle and no compression in the cylinder. At higher RPM it actually ran OK.
My question is this: If I use a dremel attachment to polish the scoring in the piston (pictured in the attachment) flat and replace the head, should I be good to go?
Old Sep 16, 2010 | 9:28 PM
old dog's Avatar
Default owie!
just smooth it and you should be ok like you mentioned .
cwatkin
Jul 26, 2010 3:04 PM
atg42
Uplander
Feb 3, 2009 8:53 AM
2004LTGUYANDGIRL
Nov 9, 2008 2:47 PM
my99s10
May 3, 2008 10:59 AM
05_mali
Jun 18, 2007 10:08 PM
