Astro 1985-2005
Platform: M-Body
code PO 430
Old Apr 24, 2016 | 2:25 PM
rparsonsca's Avatar
Default code PO 430
my 1996 astro van has a bad miss in engine and shows a obd 11 code PO 430anyone know what that code means would appreciate any help
Old Apr 24, 2016 | 4:52 PM
cleveland63b's Avatar
catalyst efficiency below threshold....fix the miss before you chase it, the only way that code would relate to a misfire is if the cat is clogged but a misfire will cause cat issues
Old Apr 26, 2016 | 1:48 PM
rparsonsca's Avatar
thankyou clevland 63b , I will fix the missfire first and then check for codes
