help needed chevy astro van fuel prob, i think
Hi there,
i,m a first time chevy owner the van is
4.3L
petrol / converted to gas aswell
astro van
left hand drive
1993
80,000 miles
I bought this van about 3 months ago and decided to get the gas conversion done as recommended for fuel consumption purposes.
The van also needed the plug and leads doing as it was misfiring alot.
I have now had the spark plug changed, dizi cap, leads, r arm and afterwards the van was driving like a dream.
Then......
went out yesterday stopped at cash and carry then when i tried to start again it just kept turning over and over like a fuel problem.
recovery came out but they didnt know very much about the make and the gas conver so all they were able to do was take me and the van home. Yes alot of help lol
Know im at a loose end.
I live in the uk so not very many know much about these models and so dont really want to touch them. And even less know much about gas conversions so i dont nkow what to do with it or who to take it too.
Any help would be much appreciated
thanks in advance
colin <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
4.3L
astro van
left hand drive
1993
80,000 miles
Then......
thanks in advance
<!-- controls -->
sorry im such a noob on these things but just turned the ignition and the psi reading is zero. dont know what it is when started as it wont start sorry.
hope this helps.
does it mean the fuel pump has packed in/ fuel filter blocked/ ????
im not really mechanically minded just trying to trouble shoot before seeking help
hope this helps.
Will it fire if you spray a 2 second shot of starting fluid in the intake. If that is the gasoline/petrol pressure, than yeah might be a bad pump. In which case I'd swap the fuel filter first to see what happens, then move onto the pump. However, I'm guessing your CNG converter installed a gauge to monitor that tank and I'm thinking 0 psi means an empty tank. Is their a switch that lets you choose between petrol and CNG?
Who was your converter and which make/model system did they install?
Hi yes had the same thing with my van. to stop and start i put it on to pet and then on to the gas and this helped starting if you have the standard air box drill 2 holes in the top as some times you will get back fire or put K&N on this helps to. make sure you clean the in take well hope this helps you. Dave
At first you must see the real fuel consumption on your Chevrolet Astro Passenger Van on gasoline and then and then do a comparison. Hear you can see the real fuel consumption on your Chevrolet Astro Passenger Van Chevrolet Astro Passenger Van fuel consumption, miles per gallon or litres/ km | Cars Fuel Consumption
Also here you can see the real tank capacity and other technical data.
Chevrolet Forum News
Oct 13, 2012 11:38 AM
94burb
Aug 2, 2009 8:06 PM
