Astro 1985-2005
Platform: M-Body
transmission or rear end grinding
Old May 20, 2008 | 12:38 PM
motokorte's Avatar
Default transmission or rear end grinding
96 safari, with 214,000 miles. runs like a top. no ticks or knocks in engine. As of right now, its making a hell of a grinding noise, similar to metal on metal brakes. but goes away when i put it into neutral, or when i hit a certain speed. Maybe when it shifts? out of first..
Does this sound like trans?
Old May 23, 2008 | 10:36 PM
old dog's Avatar
Default RE: transmission or rear end grinding
better check all your fluid'sin the axle and trans ,pull the drum's see if any thing is floating around loose . better check the rear axle mount's were the spring's mount to it they like to rust out and the axle will float around .
edit7279
Apr 7, 2021 8:33 PM
PG2676
Uplander
Sep 22, 2012 1:54 PM
Chris9793
Mar 15, 2012 9:37 PM
parker12
Aug 26, 2011 3:16 PM
chriswf
Mar 21, 2008 12:46 AM
