Audio/Visual Electronics Wired up? Got a cool sound system? Discuss all your Audio, Video, and other cool electronics here! Please limit the contents to aftermarket only. If you have questions that pertain to a certain model, post it in a model-specific section.
Help!
Old January 16th, 2011, 7:52 PM
whitelightning04's Avatar
Default Help!
I just installed a new JVC Head unit into my 2004 chevy silverado with bose speakers and on star. when i start my engine and listen to music (only when the engine is on) there is a whining noise inside the truck. Also the pitch of the noise gets higher when the the rpms are increased. Are there any suggestions?? Thanks
Old January 21st, 2011, 6:22 AM
RAM_Designs's Avatar
Check your RCA connections(if using any) and make sure they're tight, also check all grounds as well to make sure they're bare metal-to-metal contacts. You may have blown the small fuse within the radio itself, which will probably require you to manually ground the RCA's. Some pioneer units had this same issue.
luni1974
Silverado & Fullsize Pick-ups
April 29th, 2014 2:31 PM
josh46970
July 28th, 2011 12:19 AM
vwwebb
January 23rd, 2011 5:03 PM
kenney
January 31st, 2009 5:29 PM
jharper
December 11th, 2007 4:15 PM
Quick Reply: Help!
