Chevrolet Avalanche
Platform: GMT 805 & 900
02 passkey problem
Old Oct 8, 2020 | 10:39 AM
Raz Lemmons's Avatar
Default 02 passkey problem
had to change out the ignition lock housing because of passkey sensor, cranked once then quit, bypassed the sensor and cranks fine but I have no odo,gas or temp gauge, pulled cleaned and lubed ( w/dielectric grease ) sensor pins and rewired the bypass back to normal, now truck cranks fine but still no gauges ? any ideas would be appreciated, I suspect the new ignition lock housing that holds the sensor may have been defective ?
Old Oct 31, 2023 | 5:06 AM
Ace Vantura's Avatar
ignition switch or maybe a broken wire. possibly a wire backed out of a connector. did you clean the switch or contacts at all?
gmlover
Nov 17, 2018 8:53 PM
Steverenio
Dec 18, 2017 8:39 AM
gribble
Sep 14, 2010 6:41 AM
Gary 4654
Jul 11, 2010 10:27 AM
vtxchef
Jun 23, 2008 8:37 PM
