Chevrolet Avalanche
Platform: GMT 805 & 900
07 Avalanche front end noise
Old Mar 30, 2012 | 9:38 PM
k9evans62's Avatar
Default 07 Avalanche front end noise
My 07 Avalanche has a faint light squeek noise in the driver side front wheel area, I've taken it to a shop & the front end checks out good. Its has 90000 miles on it. Its only noticeable at low speeds. Almost sounds like a shock, but upon checking the shock appears good and no noise what so ever. Sound only comes from the driver side. Any help is appreciated!! Thanks Rob
Old Apr 1, 2012 | 1:58 PM
cleveland63b's Avatar
when hitting bumps? constant driving? hitting brakes? need more info
Old Apr 2, 2012 | 2:30 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> k9evans62,
The noise may be coming from the lower seat frame. This is just a suggestion, not a diagnosis. Could you provide additional information please? Is this an intermittent issue? When does it occur (i.e. when turning, etc.). "cleveland63b" also asks great questions.
I look forward to your reply.
Louis
GM Customer Service
Fireman7606
Avalanche
Oct 12, 2014 11:20 AM
thomss64
Avalanche
Feb 29, 2012 8:27 PM
TASpinney9110
Mar 15, 2011 5:54 PM
mandrus
Mar 12, 2010 7:45 PM
02TrailBlazer
Mar 14, 2006 2:28 AM
