Chevrolet Avalanche
Platform: GMT 805 & 900
'07 Avalanche turn signal problem
Old Feb 1, 2011 | 7:51 PM
mudslide's Avatar
Default '07 Avalanche turn signal problem
my 07 avalanche right turn signal has gone haywire. Blinks normal about 4 times then starts blinking very fast. Front, Mirror and Rear bulbs all blinking. HELP!!!! Can someone tell me where the signal flasher module is located?
Old Feb 2, 2011 | 10:46 AM
Drew82's Avatar
Sounds like one of the bulbs may be out and its telling you to check them auto window tinting hillsboro oregon
Old Feb 2, 2011 | 2:36 PM
mudslide's Avatar
negative...all bulbs working...does anyone know where flasher is located?
Old Oct 24, 2011 | 4:31 PM
Little River Drifter's Avatar
I have the same problem with a 07 tahoe.
Old Oct 24, 2011 | 6:23 PM
EinST's Avatar
Welcome to the forum. The BCM handles the turn signals on yours. It will hyper-flash the side if there's something wrong with the circuit, like something limiting the current flow (bulb out, too light a load, etc.). Look for a bulb that doesn't light up or lights up dim. Also, if you have replaced a normal bulb with an LED bulb, that'd be the problem.
Old Oct 28, 2011 | 7:16 PM
AVArookie's Avatar
I just had a similar problem with my 2003. R.R. turn signal would not work, checked the bulb all was fine. Fronts stayed working correctly. It ended up being a simple fix. On the 2003 there is a power module behind the r.r. tire, mounted underneath the bed, to the inner of the quarter panel. If your is similar, look up under your Av. You can't miss it, it will have 5 different plugs to it. They each control a different section of lighting and such to the rear of the Av.. I had just recently replaced this module due to the running lights stopped working on the r.r.. Turn signal, stop lights worked fine. It seems I did not push the bottom plug in all the way or something, as soon as I pushed it in, the turn signal woks fine. Hope this helps.
fishingpro77
HHR
Aug 4, 2016 12:44 AM
RomanGuzi
Oct 2, 2011 11:40 AM
IceDog
Avalanche
Feb 26, 2011 11:22 PM
dk
Sep 11, 2006 9:13 PM
