Chevrolet Avalanche
Platform: GMT 805 & 900
2004 Chevy Avalanche advice
Old May 22, 2010 | 11:57 AM
txavalanche's Avatar
Default 2004 Chevy Avalanche advice
I recently replaced all the brake pads and rotors on my 2004 avalanche and since I did that I'm hearing this grinding noise from the left, front of the truck only when the wheel is turned left. What could it be?
Old May 22, 2010 | 12:05 PM
maxxman04's Avatar
sticky brake caliper. did you grease the caliper bolts before re assembly?
Old May 22, 2010 | 12:12 PM
i greased the right side but forgot to grease the left, the side thats making noise.
Old May 22, 2010 | 12:55 PM
MDTAHOE's Avatar
Professional Mechanic
Sounds like the backing plate is rubbing.
Old May 22, 2010 | 3:46 PM
I took the caliper bolts off and greased them, it's still doing it. And there is plenty
of room between the rotor and the backing plate
Old May 22, 2010 | 6:02 PM
Could it be a problem with the CV joint?
734 Jack
Avalanche
Aug 10, 2010 9:55 AM
txavalanche
Avalanche
Jun 19, 2010 8:57 PM
buzzard08
Avalanche
Mar 7, 2010 9:58 AM
wingerak92
Avalanche
Apr 7, 2009 12:36 AM
Chuckus95
Avalanche
May 2, 2008 10:03 AM
